주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.66, 2.8, 또는 3.06 GHz Core 2 Duo 프로세서
298 질문 전체 보기
Completely unresponsive even after replacing logic board
Last weekend my MBP stopped working, apparently for no reason. A quick trip to the Genius Bar and some corrosion on the logic board behind the right fan was found. He diagnosed it as a logic board problem (loose capacitors in the corroded area). A quick trip to ifixit and I had a new board.
Pre replacement the only things working we're the mag safe and battery indicator lights. Post replacement it is completely dead. No lights, no response to SMC reset, power button press, nothing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Go over all your connectors again. You've just completed an advanced DIY many times connectors that "looked/seemed/thought" connected were later found out not to have been square and snapped in, ribbon cables not inserted fully or upside down, cams not locked.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I quadruple checked everything and removed the logic board finally reconnecting each cable one at a time, when the keyboard cable was reattached the issue started again.
I tried reconnecting my original logic board (having cleaned up the corrosion and seeing no board damage) and the same thing happened again. As soon as the keyboard was attached the light on the MagSafe connector would not light up. Upon further examination (AKA complete dis-assembly) it looks like the real damage was to the keyboard (I can see a water spot but i still have no idea how it got wet).
A quick trip to eBay and a gutted MPB for parts later and I'm good to go.
댓글 달기
귀하의 답변을 추가하세요
bryce 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 137
