no sound from output or speakers
I get no sound from speaker or form output on macbook late 2008 unibody 2ghz,but i get sound from headphones on bluetooth.what is the problem. help
좋은 질문 입니까?
좋은 질문 입니까?
The headphone socket has a small switch inside so when you remove the plug the internal speaker is driven. It sounds like you may have a dirty switch or damaged it with a mis-shaped plug or just from a lot of use. Using a dentist probe and a magnifier see if the switch is working and if needed try cleaning it. In some cases the switch shifts so the contacts don't touch using a toothpick try rotating back the contact. Use the Mic outlet as a guide as it's the same socket.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 237
