주요 콘텐츠로 건너뛰기
Samsung Galaxy Note II는 대형 스크린과 필수 자체-저장 스타일러스로 최적화된 소프트웨어가 결합한 스마트폰입니다.
211 질문 전체 보기
Why does my Power button work sometimes?
I have a Samsung Galaxy Note 2 from Verizon. A few nights ago I put it on my window sill and it sat in a very shallow puddle of condensation from my window air conditioner unit. I immediately put it in rice for 48 hours.
The problem that I'm having is that the power button is responsive sometimes. Most of the time the button doesn't work at all. I opened up the unit and took a look. There is no noticeable moisture inside of it at all. Just to cover my bases, I removed the power button and reinstalled it. I also briefly ran a hair dryer over on low heat to try and evaporate any remaining moisture that I might have missed. My issue still seems to be the same.
It will just randomly turn on and then will seem normal for about 30 minutes (button fully works). Then the power button will just stop working.
Does this sound like something shorted out on the mainboard, or is there something else that I can try?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
There might be "JUST ENOUGH" corrosion in it to make it act this way. My Galaxy S2 Skyrocket also does this but mine only stops working occasionally. I dropped mine in a bowl of cereal (please don't ask) and have it's had some hard landings at work onto some big drills without a case on. Sometimes if I give my phone a smack on the back it'll work again normally. Not too hard, but it helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I recently experienced the same issue after getting caught in the rain. A few droplets must have entered the casing, because soon my power button started acting up.
At first, it would work intermittently. Sometimes I would even see the phone screen flashing on and off, as if the power button was continuously short-circuiting. Eventually it stopped working altogether.
This wasn't much of an issue because I could turn on the screen by pressing the Home button, and turn it off using a widget I downloaded and placed on my home screen.
But like an idiot, last week I shut down the phone for whatever reason. Now I can't turn it back on... because the power button doesn't work. Stupid.
I opened up the phone and as soon as I touched the power button (the part that actually goes click-click), it literally fell off of the ribbon. I guess the connections must have rusted through.
I have ordered a replacement part. Fingers crossed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I was having the exact same problem. The power button was flush with the phone bezel and it was extremely hard to power on. You would have to press the button very hard and sometimes press against a desk's edge to power it on.
My note 2 has a small screen crack just below the home button and is still under warranty. I decided to send it to Samsung for repairs asking only to fix the power button not the small less than half inch screen crack. They declined to fix it because a screen crack voids warranty. They had to phone for 3 weeks before sending it back to me. Ridiculous.
I got it back and decided to fix it myself. I didn't have any special tools but here's what I used:
1x old plastic credit card
1x plastic card (half the thickness of a regular credit card...I used my old student ID card)
1x small Philips screwdriver
1x flat head screwdriver
1x roll of 3M Magic Tape
I followed the instructions from this video:http://www.youtube.com/watch?v=UT-2zrZ_a... to take out the screws and take out the mid plate. I've never fixed a phone like this before so I watched it over and over again. I didn't have the blue plastic tool to take out the clips so I used my student ID card to make an opening and used a credit card and ran it along to the edge to pry open the clips. Used the same method to open the two clips battery is, except on one side I used the flat screwdriver just like the guy explaining in the video.
Once the plate is out, you can skip to 6:43 in the video to see where the power button ribbon is. Now when I removed just as Alex said...three pieces fell apart:
2x sliver colour round thin pieces
1x brown piece with a black thing on one side
Its because 3 pieces aren't aligned properly your power button is not working properly.
The brown pieces has to be sandwiched between the two silver pieces (make sure all three are centered) and the black thing has to be facing towards to power ribbon not the button on the mid plate. Once all three are stacked on top the power ribbon cable side I taped with small strips of 3M tape to hold it together. It took about an hour to put this section together.
Test it. Press the whole thing and you should feel the brown piece with the black pointy thing clicking...at this point your phone should power on. Next just slide the mid plate back into the phone and once you hear the clicks that means the clips are in and sealed. Watch the guy's video...he explains it very well. Put the screws back and you are done.
Sorry I only have one pic... http://i.imgur.com/XvZTJIB.jpg
You can try and replace the power button ribbon but not sure if it comes with the three small pieces. I definitely saved at least a $100 rather than going to store and getting it fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I really hope this works, if so, thank you, i'll try later today.
댓글 달기
check to see if you have downloaded any recent apps that may conflict with or could cause trouble... I'm having the same trouble, when i press my power button on my note 4 to wake my phone , nothing happens, i have to press it like 5 times... it just started happening and i hadn't dropped , damaged, no water , nothing, i started uninstalling apps one by one in reverse order and it turned out to be a generic galaxy note 3 lock screen i downloaded for my note 4 that started causing the issues... best of luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Josh 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 15,102
