Why does my mac keep making this weird noise?
My MacBook keeps making this weird noise when I turn it on or open it. I think its the fan but I'm not so sure because I also think its the battery. Does anybody know what it might be?
좋은 질문 입니까?
좋은 질문 입니까?
Normally the Book will try to access the optical drive first. (whirring noise), Then it goes to the hard drive (sometimes a clicking sound). A squeeking noise can be made by capacitors going bad. Fans can make a screeching or chirping noise if going out. It all depends on the type of noise, and the location. Is this a new noise? Remove the battery and start up with just the AC adapter connected to eliminate it first. As rj asked, a better description is needed to help you.
해당 답변은 도움이 되었습니까?
+ Ralph
I just looked up "reason Mac would start making noise on start up" and found this thread! My new Mac (got it about 5 months ago) suddenly started making a noise on start up that seems to be coming from the right-hand side where the DVD player (sorry can't think of what it's actually called) is. It sounds like it is starting to play something or moving- hard to describe otherwise...like vvrmmm...vrummmm (lol), like switching back and forth. It never used to do it and I'm a bit worried because now it does it with every start-up. I don't believe I've ever used the player part before either.
Thanks for any help
; ) Danette
해당 답변은 도움이 되었습니까?
Get a ROBLOX account, play prison life 2.0 WITH a hacker or just have crappy wifi, play a different game, get triggered hit the computer as hard as you can until it goes away
해당 답변은 도움이 되었습니까?
yo cheers for that one, i started to it my laptop and it actually fixed it!
LMAO XDDDDD that might work
because you keep squishing it thats why its making that sound
해당 답변은 도움이 되었습니까?
Oh yeah when I pressed down on the bottom left corner of my Macbook Pro it makes the clink sound. Thanks
yes i do beat up my macbook regularly
24 시간 전: 1
7일 전: 12
30일 전: 34
전체 시간: 30,462
댓글 7개
Can you describe the noise better? Ralph
rj713 의
I got it too. It repeats several times until it starts loading.
40coolguy60 의
i am facing the same problem with my Mac book pro which is two years old. Please let me know what to do . only difference is that the noise rare and it happens while opening the mac book.
annapurna 의
I have the same problem please help me out how do i fix it now....
Smick 의
@mailes - Smick you'll need to give us more than this. You should also create your own question as this one is quite old.
Dan 의
댓글 2개 더보기
