Where exactly is the Flasher Relay for a 2003 Mazda Protege located?
좋은 질문 입니까?
좋은 질문 입니까?
Berry, the Turn signal/Flasher relay is under dash on drivers side. If you have a manual transmission is is almost directly above the clutch pedal. It is a gray colored box about 2 inches wide by 4 inches long. It is #5 in the attached diagram.
Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
Thank You very much , it solved my problem.
Thanks
Ronald (Philippines}
24 시간 전: 2
7일 전: 5
30일 전: 19
전체 시간: 11,246
댓글 1개
Thanks oldturkey03! I will check this out immediately.
Berry 의
