주요 콘텐츠로 건너뛰기
My laptop has a cooling issue
For the past year or so my laptop has developed a cooling issue. It gets very hot and the fan is noisy. This is more noticeable when running Windows than Linux (it's a dual boot) and when running demaning software, but that's obvious I guess. I recently changed the harddrive and tried to clean it when I had already opened it up, but I found it hard to actually access the CPU, which I imagine is what is causing the problem. The hot spot is mainly the bottom left corner, under my left hand. I've been considering opening it up again and see if I can clean it again, but it really didn't have much effect. I've also thought about cooling paste, but since I couldn't really figure out how to access the CPU that seems difficult. Google has not been helpful so far.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Sannfog, get the service manual from here, disassemble your laptop according to the manual. Clean all the air intake vents, and since your fan is noisy, replace the fan. clean the heatsink and apply new thermal paste. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
2 댓글:
Thank you. This sounds like a project for the weekend :)
Sounds like a plan:-) Best of luck to you.
댓글 달기
귀하의 답변을 추가하세요
Sannfog 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 292
