주요 콘텐츠로 건너뛰기
임상 환경에서 사용되는 의료 기기 설명서 및 지원.
15 질문 전체 보기
Can I replace the transformer in a NovaSonic Pain Reliever?
I am in the UK and I have a NovaSonic Pain Reliever.
My transformer works on 240VA and tranforms to 14,5VA - 6,5VA 120degrees
The casing is broken.
Is it easy / is there somewhere to buy transformers of different outputs?
Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
안드로이드 수리 키트
A new screen or battery is one kit away.
지금 장보기
안드로이드 수리 키트
지금 장보기
2개의 답변
선택된 해법
if the transformer is not working try to replace the transformer with same outputs...different output
transformer may damage your device..and it is very easy to fix it
you just need some glue, screwdriver and soldering kit and transformer.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
The short answer is DO NOT attempt to repair ANY medical device unless you are qualified, as in Biomedical Engineer!
Medical devices must pass rigorous testing, and standards. Doubly so when it comes to electrical/electronic devices due to the danger of electrocution. ALL transformers used within medical devices are ISOLATION TRANSFORMERS to isolate the patient side of the device from the AC power supply side of the device. You cannot just buy, and use any old Chinese made, off-the-shelf parts in medical devices. You're just asking for fire, injury, or death! DON'T BE CHEAP! Either have this repair done by the manufacturer, a qualified Biomedical Engineer, or bin it and buy another one. I know about which I speak. I'm a now retired OR RN of 30 years that is highly trained, and qualified. I am trained, and qualified to do adjustments and calibrations on certain devices, and equipment. I worked closely with Biomedical Engineers, and other qualified individuals. Please do not risk your life or that of others to save a little money.
해당 답변은 도움이 되었습니까?
점수 -1
의견 추가하세요
귀하의 답변을 추가하십시오
Emma 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 355
