2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3322 질문 전체 보기
Dropped my iPhone, digitizer replaced but still not working?
Hi everyone
I dropped my iPhone 5 and the LCD / Digitizer both got broken.
I replaced them with a new part from eBay and the LCD works and all functions on the phone work (that I can see) but the digitizer does not recognize touch.
I have tested the digitizer on another iPhone 5 and it works perfectly.
I restored the iPhone and it still will not work.
Does anyone have any ideas? I assume it is hardware damage? The digitizer connector on the logic board looks fine and I cannot see any other problems. The phone has also never been water damaged.
Thanks, Ryan.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Hi I have the iphone-5s - two different companies have replaced screen and digitizer - neither company could solve the problem - after replacement display works but it will not allow you to input the passcode - ie it doesnt recognise the finger touch ... any ideas
thanks Gray
의 답변
Servis destroy your home button touchID reader - since is unicate for each phone , replacement does not read fingerprints and there is no way to repair
의 답변
I have similar problem. My iPhone was water damaged, and after that everything works, but touchscreen isn't responsive.
Does anyone knows what can cause this?
Znas li ti Milose?
의 답변
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
3개의 답변
선택된 해법
The Tech Genie, check on here step 18 will show you the location.
Orange = Texas Instruments 27C245I touch screen SoC
Yellow = Broadcom BCM5976 touchscreen controller
Rather than a single touchscreen controller, Apple went with a multi-chip solution to handle the larger screen size." Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Look very closely at the pin connections on the logic board sound like the one that plugs into the digitiser got damaged
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thanks for the suggestion. I checked the connection on the board and it looked perfect to the eye, even under a magnifying glass.
Is there a certain part of the board that deals with the digitizer on the iPhone 5?
의 답변
Have You ever found the solution for this issue?
Kind regards.
의 답변
의견 추가하세요
I'm having the same problem. Been trying to fix this 5c since forever. I've got the screen replaced, got it check out, iphone Techs. couldn't fix it. I'm more thane sure our problem would be solved if we all bought new logic boards, but they are crazy expensive.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
The Tech Genie 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 11,508
