주요 콘텐츠로 건너뛰기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
142 질문 전체 보기
When I install Snow Leopard, Select Drive option shows no drive.
I have a Mac Mini A1176. I have an install disk. I upgraded to a 1TB Hard Disk Drive. When I put the CD/DVD in with the Snow Leopard OS, it goes through the process. When it come to the option to select the drive you want to install the OS on, there is no HDD to select. When I look at the drives, I can see the 1TB hard disk drive, and the CD/DVD, so I know that it is connected. It just does not show up in the "select drive you want to install the OS on" option.
Any ideas, anyone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Perhaps you formatted the drive in other than GUID - a requirement to install a MacOS.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Use Disk Utility in your startup disk to format your 1TB drive in the Mac Journalled choice.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Darek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 329
