iPhone4s is overheating and drains battery fast after water damage?
The phone was dropped in a pool. It went 10 feet deep but was fished out right away. My friend put it out in the sun to dry for 2 hours.I dried it on the inside by carefully drying the internal parts excluding the display area with a paper towel, then putting it a mixture of rice and packets of silica gel to absorb any left over moisture, but i didnt receive the phone for about a day, so there wasnt much inside. i replaced the battery and it turned on but it would burn up charge faster then it would receive charge. also the antenna dead, i think that might be related to it, but I put it in airplane mode and it still continued to use juice. Perhaps a short within a non essential part? I have disassembled the phone and reassembled it when i was drying it. I was able to turn it on and it worked but it burns energy faster than I can charge it. I have tried disconnecting a few parts and then plugging it in but it still heats up so it isn't the camera or the buttons.
좋은 질문 입니까?
댓글 2개
How did you clean it? What have you done to prevent corrosion?
oldturkey03 의
I cleaned it with a paper towel. I didn't clean in deep because I didn't want to mess with the sensitive parts. I put it in silica gel packets and rice to remove any remainder
vanish172 의
