주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Replacing battery went wrong won't turn on, any ideas?
My macbook battery had been swinging from "condition normal" to "service battery" so I thought about checking the connections/cleaning it up and also to inspect it for swelling.
I opened up the macbook and took off the battery. Apart from a bit of dust it looked fine so I proceeded to connect it back in.
As soon as I finished I checked if it booted and it won't turn on.
The battery indicator lights do not light up, connecting the power adapter shows only a dim green light on the adapter.
I tried also powering it up with the battery disconnected but and with just the AC but it does not show any sign of life. The adapters's light keeps showing only a dim green.
I checked also the battery indicator flex cable and it looks fine. I also tried a SMC reset by disconnecting all power sources and pressing the power button 10s but to no avail.
So, is a macbook mid 2010 or recent able to boot without a battery? - If so I might need a new logic board - or does it need a battery to boot? - this means I might be able to get it back in order if I replace the battery.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Try the SMC reset !
Remove all external devices from USB, connect power supply. Hold down shift + alt + power button for a couple seconds. Release and press power, maybe it´s fixed !
Colin P
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
sergiojardim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,283
