power button does not work after replacement
I have replaced my power button because it did not work and now it depresses and clicks but still does not activate. I have gone back through the steps again and it still does not work. I am beginning to wonder if i damaged the power and sensor cable when it put it in?
좋은 질문 입니까?
댓글 6개
are you talking about the home button? or lock button? I am having the same problem with my home button... ive tried a bunch of time to reinsert the little prongs but i dont know if i damaged something, if you got yours to work, help me out
Thanks!!
Rachel 의
Hello!
Did you replace the lock button flex cable? Or did you just replace the metal button that you press?
Josh Wright 의
I replaced the flex cable under the power button. The power button now depresses properly but does not carry out the actual turning on or of the phone.
I think i damaged the new one when i installed it in the phone. I will try again when my replacement arrives.
Nathan Turney 의
Does the phone still function and turn on? It could be that the phone is non-functional anyway. And okay get back to us with the results :)
Josh Wright 의
The phone works fine! All apart from the power switch:-( I will try to repair it again and if it doesn't work then so be it:-)
Thanks for your help:-)
Nathan Turney 의
댓글 1개 더보기
