주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
SanDisk Cruzer Glide는 접이식 USB 단자를 갖춘 USB 플래시 드라이브입니다. 다양한 저장 용량으로 출시되며, 모든 모델이 검은색과 빨간색 플라스틱 케이스로 구성되어 있습니다.
I can't erase file
Hi, I purchased this unit at Office Depot and would like to use it fully as a Mac unit. However it came with a 6MB Windows file called U3 System. Normally I wouldn't care about the 6MB but every time I use the stick I have to separately eject this file. Its a nuisance I would like to be rid of but get info says I can only read the file. Anyone know how I can delete it? Ralph
I have tried to delete this thing every way I know. In get info its listed as a read only file. Ralph
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
선택된 해법
You can download a utility here that may let you get rid of it:
http://communities.sandisk.com/sandisk/b...
이 답변이 도움이 되었나요?
점수 5
댓글 2개:
That did it---thanks Ralph
good going +
댓글 달기
Try connecting it to a windows computer, then launch the U3 program, and navigate to the option of "remove U3 smartdrive software" (Or something such as that) and that will remove the file. I have 2 Sandisk Cruzers, one 2GB and one 16GB and the only way i have been able to get rid of U3 it through those means. Reformatting, erasing, and flashing the drive do not remove it, and that appears to be the only way to do it.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thanks for the answer Chris but I no longer own a Windows machine. Thankfully Tims solution works in Mac. + for the good try. Ralph
댓글 달기
You could always just reformat the drive through disk utility. I think this will probably be the best bet in this situation.
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
Tried that--didn't work Ralph
Wow, did it format at all or just error when you tried?
What did it say when trying to format?
It did not give a message--just refused to format that partition. Ralph
댓글 달기
Tim, I tried your sandisk link at the top of this page and it says no longer a valid link. I have a Flash drive with a "virus" on it and it keeps flashing there and not there. Won't exist long enough for me to reformat. Looking for solution.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
would this one work mp3support.sandisk.com/downloads/cruzer-utility-mac.dmg
댓글 달기
Alan,
your drive might not be getting enough power to operate. I had the same issue with a 4GB USB flash drive, and using another computer and plugging it in directly (without going through USB hubs ets.) worked. You may have to try more than one computer to get it to work properly.
However, if the flash drive worked fine on the same computer it's now having problems with and spontaneously started having problems, formatting it may help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
rj713 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 24
전체 시간: 18,492
