No service after battery replacement?
I replaced the battery in my iPhone 4S, since then the phone says 'Searching' or no service in the upper left corner. I tried switching the date back to 2013 but the problem still persists?
좋은 질문 입니까?
좋은 질문 입니까?
Check to make sure you didn't damage/disconnect the cellular antenna when removing or inserting the battery. It's cable runs along the spear assembly parallel to the bottom of the battery.
This link shows you where it is and how to replace it.
iFixit_Iphone_4s_Cellular_Antenna_Replac...
If you need the part: iPhone-4S-Cellular-Antenna
해당 답변은 도움이 되었습니까?
What you have to do is just connect your iPhone to iTunes via data cable for 2 minutes.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 4,436
