iPhone 4 CDMA not turning on without being plugged into charger.
I have an iPhone 4 CDMA Verizon that had a a broken digitizer but LCD was working. I purchased a replacement digitizer and LCD and replaced the screen with no issues. BTW, I have replaced 20+ iPhone 4 and 4S screens with no issues.
When I went to turn on the phone it wouldn't turn on. I double checked the battery connector and everything was correct. I then plugged in the phone to a wall charger and the phone booted up. I unplugged the charger and the phone turned off.
I suspected the battery could have been bad but the phone wasn't experiencing these issues before screen replacement. I swapped another known good battery in and the phone is experiencing the same issues.
I have disassembled the phone and double checked everything and still have the same issue. I read that it could have been a battery pad port that was damaged but I was unable to see any damage.
Anyone have any tips or suggestions?
Thanks
좋은 질문 입니까?
댓글 1개
those battery contacts are pretty easy to loosen when you lift the battery out..I'd take a good look at them where they connect onto the board. I've had one or 2 cause a problem like this.
pollytintop 의
