주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
phone in restore mode and won't even charge
I bought a 2nd hand iphone 3gs some weeks ago. Noticed it was running ios 4.1. phone wouldn't run anything such as Facebook - said I need 4.3 or more. Tried updating on pc - kept timing out. Friend suggested full restore, so I did. Phone is now not functioning, and will not even charge. I understand NOW, it was jail broken by the previous owner as it had Cydia installed. Is there anyway I can get it going again? Fix it shop seemed to think not as it wouldn't talk to their pc.
thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
you can try downloading iReb or tinyumbrella to get it out of recovery. To get it updated you need to download custom firmware..this is why iTunes is not wanting to recognise your phone-it can see that it doesn't have the original/apple firmware.
댓글 달기
답변 1개
선택된 답변
You can delete the lib files so that itunes see a new phone and install apple firmware, or if you want to keep your jailbreak you'll need to download something like redsn0w etc... google jailbreak 4.1 3gs and see what you come up with this is one way.
to delete your files a better link for mac osx
Mac, Go to ~ / Library / iTunes /. In the Finder, you can choose Go> Go to Folder. Type or paste the path name above and click OK. - Delete all files in the iPhone Software Updates and Device Support. - Try to restore the iPhone again.
On Windows, these files are located in a hidden folder. To view these files in Windows Explorer, you must select Tools> Folder Options, click View, then select "Show hidden files and folders.
In Windows Vista, follow the instructions below: - Go to Start> Computer> Local Disk and type the following path: C: / users / [yourusername] / AppData / Roaming / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates folder and Device Support. - Try to restore the iPhone again.
In Windows XP, follow the instructions below: - Choose Start> Run, then type C: / documents and settings / [yourusername] / Application Data / Apple Computer / iTunes / - Delete all files in the iPhone Software Updates and in Device Support.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
claire 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 51
