주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
779 질문 전체 보기
black screen upon booting
My macbook pro was working fine. However when I turned it on a few minutes after shutting down I was greeted with a idle black screen. I went online to find answers and there were numerous cases about the 2010 macbook pros. However I have a 2011 macbook pro so I know that they weren't caused by the same issue. I tried resetting the smc, pram, booting into safe mode. No luck. What do you think is the problem? Do I need to replace the logic board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
First step is to connect to an external monitor to find out if this is a bad VGU/VGC or if it's limited to the internal (onboard) display chain.
If you have video on the external monitor your logic board and VGU is ok... you should then try to boot to an external CD/DVD Drive or boot into Repair. (leave the monitor connected) run repair, run AHT.. see if that does anything helpful. Your problem might be software/HD related
If there's no external video either then you have serious problems with your VGU or Logic board.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Seiyun Ki 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 704
