주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
Is it the LCD that's messed up?
I dropped my iphone and the screen went black. is it the LCD that's messed up? if so, cant I just take it in to get the screen fixed since you have to replace the LCD anyways? (praying that that's correct.)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
Try doing a hard reset by holding sleep and home for up to 10 seconds. If that doesn't bring it back, then it could simply be a loose LCD ribbon. Take off the back cover. Disconnect the battery which is held by one ore two screws depending on your iphone, then remove the very top EMI shield. Should be 4-5 screws. There should be two large ribbons to the right of the camera. Disconnect and reconnect. Reconnect battery and turn on the iPhone. If it still doesn't illuminate, disconnect the battery again and disconnect and reconnect other ribbons underneath the other EMI shields. If the LCD still fails to illuminate, then it's possible your LCD is damaged and will require replacement at that point. Best of luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bayonleolayiwola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 1,469
