주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
382 질문 전체 보기
Damaged LVDS Socket, lost pins. Maybe Panel @ DisplayPort?
I´m such a fool. I damaged my LVDS Socket on my iMay 27 mid-2010.
Pic:
https://dl.dropboxusercontent.com/u/3112...
can i replace or fix it? or it is possible to connect the panel on the DisplayPort?
Thanks in advance.
Update
THANKS! i have a friend that can do this (study electric).
i have a second question:
can u tell me what is it? it´s a little bit broken, maybe this can be a reason to?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Hi
The connectors referenced by Christoph could fit your needs - but be aware that it is pretty easy to burn the solder coating with a normal solder station. Use a 5 watts type like you would be using for SMD type boards and soldering.
Of course you could solder the wires of the LVDS cable directly to the board, but that would not be easy to do.
Regards, Stone
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Hi Christoph
That would be the right guy to do the repair ;-)
I am not sure about the thing shown in your second picture. It looks like a connector, too. What seems to be broken is the isolation - so it comes to the plug if this will dangerous or not (if the plug is fully covered it should not be a problem).
But I have to say, I am not that familiar with iMacs (cause I do not have one nor had) - can you please tell me what is normally connected to it or do a picture of the whole board just marking the connector?
Thanks, Stone
댓글 달기
귀하의 답변을 추가하세요
Christoph 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,434
