주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
White screen after replacing LCD cable?
Hello I am new to this forum, and some what familiar with MAC repairs.
I am having a problem with a 1st GEN Macbook air A1304. The hinges broke which is common on these and the LCD cable ended up ripping a little, with very little pressure on the cable i could get the display to work.
I recently decided to replace the hinges and cable so I can start using the Mac again. After I completed the install of the new cable and hinges I powered on the Mac and white screen. I can hear the boot sound and the hard drive running, so I hooked it up to a external monitor and it works. I have tried the PRAM and SMC reset still nothing. After that I was messing with the cable to see if it was still loose or something nothing but now I am just getting a black screen, so I am assuming I messed up another cable so I order a new and waiting for it to ship.
My questions are. What is causing the white screen after the cable being replaced? Could it be a bad LCD screen? And what are the symptoms or things I should check for it to be a bad LCD screen?
I will also note I have done a lot of reading on this issue and have heard of people replacing numerous cables and numerous displays and still have the same problem.
So if anyone else knows of anything else I can do to possibly fix this I would greatly appreciate it.
Thanks,
Roy
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Follow this thread for some ideas.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Hello again I now have a new issue I found out it was a bad LCD screen I replaced the screen and put in a new LVDS cable. Now my problem is I have no backlight could I have possible blown a backlight fuse? If so is there a diagram I can follow to locate it? Also if there is any other solutions to this problem I would appreciate it
Thanks,
댓글 달기
귀하의 답변을 추가하세요
Roy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,267
