How do you repair the keypad numbers that won't function?
My wife dropped her phone in a bowl of water. It was quickly removed and dried as best possible. Now, the number 9 key and her address book key don't work. Is this fixable?
좋은 질문 입니까?
좋은 질문 입니까?
I would say - maybe
water damages are sometimes bad - even if the look tiny.
the w760 has 2 ribbon cable keypads.
the contacts of the non working keys can be burned - in this case a repair can be tough - but with conductive silver would a repair be possible.
on the other side - the keypads are sold on ebay - but those parts can cost a fortune (up to 50$ together, the complete phone cost 99$)
so, fixing it would be the best way.
here are some youtube videos (take a look at the video list)
the keypads are looking similar to this
clean the keypads carefully with rubbing alcohol and a soft cloth
해당 답변은 도움이 되었습니까?
I once went swimming and realized afterwards that I had my Motorola L2 phone in my pocket. I tried turning it on afterwards and it appeared to be completely dead. Here is what worked for me:
1) Remove the battery
2) Place the phone (or other device) in a sunny window where it will get a lot of direct sunlight, with the display up and the battery cover removed so the water vapor can get out
3) Let it sit for a few days until it has dried out completely and try it again.
After a couple of days I re-inserted the battery and tried it again and the phone worked fine. I have used this phone for several years since this happened without any problems. As a rule, water (if it is relatively clean) does not do catastrophic damage to electronics. The main things to do are to remove the power and *gently* dry it out completely.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 7
30일 전: 8
전체 시간: 2,657
