주요 콘텐츠로 건너뛰기
Tiger Install after drive replacement
Hi,
My girlfriends iBook G4 1.2gHz hard drive quit. I replaced it and while trying to install os 10.4.11, I get install errors. The disk utility says everything is fine. The drive that came out was a Samsung HM060HC 60 gB, 5400 rpm, 8m, PATA. The one thats going in is a Hitachi Travelstar 60gB, 7200rpm ATA/IDE. Could the drive type be the problem or is there something else?
Thanks in advance
Mike
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
Could be the drive - the industry nickname for that model is "Deathstar" because they are so problematic. The Disk Utility is a pretty lightweight tool - try a reformat (partition) before reinstall - on that age machine it could be your optical drive or even damage to the install disk.
If you have another drive you could try to install your OS on that, boot from it and clone (or apple restore) it back to the internal drive.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
I tried an external drive as well. Same result HOWEVER, I used the same os disk to install to another machine.
Thanks MacHead,
It was the ram. Good advice!
Mike
댓글 달기
귀하의 답변을 추가하세요
msovin55 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 89
