주요 콘텐츠로 건너뛰기
2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
418 질문 전체 보기
Very slow 802.11n airport conection and lack of range
I replaced the airport card in my A1811 MacBook with a MacBook Pro several years ago and have not had the range or especially speed tha t was expected - virtually no improvement over the orginal card. The card is supposedly Apple # MA688Z/B. Is there firmware/ software or an antenna wiring problem. Is this the same card that you are selling for the update the Core Duo?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
I have susequently reversed the antenna wires at the (802.11n) airport card within the MacBook and now have satisfactory speed at 60+ feet.
댓글 달기
답변 3개
선택된 해법
Did you update the base station also? You won't see n speeds without an n base station. Ralph
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
maybe its not your computer but the wifi base stations you connect to?
or something upstream?
your antenna could be part od the problem too.
this is a brad question - can only elicit a general answer
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I have updated the base station - airport extreme to the latest software / firmware. I feel it is related to the antenna as the closer I get to the base station the faster it gets. When I am over 30 feet it is very slow. My new MacBook works very well this distance. Could I have hooked the antenna wires up backwards or do I need different antennas?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
your ld antenna may not be working well with the frequencies used in 'n'
IIRC we have 2 bands of frequency used in WiFi - so your suspicion could be correct
댓글 달기
귀하의 답변을 추가하세요
minicoopers 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,896
