MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
4112 질문 전체 보기
How to fix a jammed DVD/CD
I've been working on repairing an A1181 mabook. My little brother jammed a DVD or CD in it...then attempted to forcefully remove the disc with out using any of the commands or other normal tactics to remove a disc. So now its extremely stuck. The optical drive has taken to making terrible grinding noise and sad whimpering attempts to eject the disc.
I've tried all the different computer short cuts to remove the disc from the basic hitting the eject button to starting the computer in the single user interface and trying to type the command there.
I'm guessing the drive is permanently damaged by the sound it makes, but I am still hoping to atleast remove the disc.
There is a screw stuck in the frame as well (not stripped, just stubborn)
If you can I'd like some advice and tips for opening and removing the disc, if its feasible and the possibility of further damage. Would it be a better thing to just take it in for a repair?
many thanks for the help!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
There are some suggestions for dealing with stuck/stripped screws at the right. You might try the double sticky tape method of optical media retrieval.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글:
thats a great idea! its a full sized disc, do you think it will still work?
의 답변
Has for me. =8^)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Alexis 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 312
