cycle lights blink washer will not run
washer will not run . no codes, cycle light will blink once when start is pushed
좋은 질문 입니까?
좋은 질문 입니까?
Unplug it for 5 minutes to allow it to reset then plug it back in and see if it gives you any codes.
해당 답변은 도움이 되었습니까?
the door lock light didn't come on. when I unplugged the electric and plugged it back in the door light came on. it ran thru a couple minutes then shut off when the door light went out. can you help me? thank you.
fred
해당 답변은 도움이 되었습니까?
when i put a load in it starts and then stops and the light start blinking and i have to move the cloths around in the drum - or take some cloths out - but that only works sometimes.
해당 답변은 도움이 되었습니까?
Washer stopped with twelve minutes left on the timer clothes are dry enough to take out.the washer will not restart. I unpluged the machine for five minutes and when plugged back in no code appeared. When it was plugged back in a real low hum could be heard but still will not do anything
해당 답변은 도움이 되었습니까?
After turning power on I push the start button and hear a humming noise. Please help
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,097
