2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
352 질문 전체 보기
did not charge when I was doing my project
Hi,
I am a newby here, my MBP 15' (late 2011) did not charge when i was doing my project yesterday, the green light were disappeared, battery percentage dropped to 56%. I google the issue, I then realize that my battery is acting strange and please take a look at the MBP System Report stated as below: -
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 406
Hardware Revision: 2
Cell Revision: 158
Charge Information:
Charge Remaining (mAh): 469
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6289
Health Information:
Cycle Count: 83
Condition: Normal
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 11040
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Wake on AC Change: No
Wake on Clamshell Open: Yes
Wake on LAN: Yes
Current Power Source: Yes
Display Sleep Uses Dim: Yes
GPUSwitch: 2
PrioritizeNetworkReachabilityOverSleep: 0
Standby Delay: 4200
Standby Enabled: 0
Battery Power:
Display Sleep Timer (Minutes): 2
GPUSwitch: 2
Reduce Brightness: Yes
Standby Delay: 4200
Standby Enabled: 0
Hardware Configuration:
UPS Installed: No
AC Charger Information:
Connected: Yes
Revision: 0x0000
Family: 0x0000
Serial Number: 0x00000000
Charging: No
I tried almost every mattered posted on the website such as SMC, reset PRAM but I still couldn't resolve the problem, after that my battery percentage went down to 7% and my battery is not charging!!! Is my battery died and needs to be replaced a new one? Any advise would be very much appreciated.
Thanks & regards
KL
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
I would first check your wall outlet - then try a different or new charger.
If there was no liquid damage or falls the DC-in board and battery should be ok. However if you've dropped, squeezed or stacked something on the laptop there could be internal damage.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
kenneth Liew 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 82
