주요 콘텐츠로 건너뛰기
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
160 질문 전체 보기
Broken Headphone tip stuck inside PS vita
So my headphone jack broke inside my ps vita, i have tried getting it out with a pair of pliers and small objects to no luck. should I go about opening it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
The headphone jack is connected directly to the motherboard, and there is no way to remove it without soldering (reference: here and here)
I've read that getting a very small drill bit (#76) and applying some slight side pressure and flicking out may work.
I've also personally had limited success (read: one time) of very carefully and VERY gingerly drilling out the middle of a broken-off headphone jack with a tiny drill bit, then extracting with dentist tools. I'm not suggesting this as the BEST course of action, but it is possible. If you attempt, make sure you have a way to secure things so they don't move about when you're drilling. (A vise with soft pads perhaps) and be careful.
Cheers!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Sebastian Mundo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 656
