diagnostic led blinks once when ac is connected
The Imac emc 2389 won't boot. There is no chime no beeps and just a black screen. I bought this computer used and non-working. I was told the power supply was bad. I swapped the power supply and ram from a working mid 2011 emc 2428, no difference.
I removed the glass and screen to access the diagnostic lights. Number one diagnostic led blinks once when I connect the ac cord then goes out. When I push the power button it blinks once more then goes out. No other leds light up. Any suggestions. I do have a multimeter and know how to use it. Thank you in advance
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
Some others with this behavior no LEDs lighting, replaced power supply. dead. AC line filter?. You could remove the HD and see if you can boot to an optical or external drive. Or, put the HD in an external case and test it on another (working) Mac.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I removed the hard drive and optical drive and tried starting the computer. Same results. I also installed a working hard drive still have the no.1 blinking led.
의 답변
You need at least one boot drive. Since removing the drive did not change behavior I lean toward a PSU (power supply unit) problem.
의 답변
Working on power supplies is very dangerous for a DIYer. To get an idea (this is not the correct power supply-but an example) look here to see what's involved in testing the output voltage. You are working with mains power, and capacitors that store enough voltage to kill! Do not work alone.
의 답변
의견 추가하세요
Are you any further forward with this issue? It points to a bad PSU but unfortunately at this stage you cannot rule out a problem with the logic board either.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
hwallycarlson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 791
