주요 콘텐츠로 건너뛰기
iPod Doesn't Play Music or Video
This iPod charges, and syncs to iTunes. But when it is turned on, it displays a sad iPod icon. If it is turned on after that, it comes on normally, you can navigate through it. Yet, when you try to play music, the count stays at 0:00. I believe the headphone jack is okay because when inserting and removing headphones, the play/pause icons in the corner changed. When you try to fast forward in the song, it still does not play. Additionally, videos do not play, and the iPod freezes when you try to.
I've narrowed it down to either the hard drive or logic board? Has anyone experienced and repaired this problem? Thanks for your help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 7개
have you tried a reset and / or restore from itunes?
does anything else work (clock, stopwatch etc?)
Sounds like it functions, so not the logic board, sounds pretty much like an HD failure
Yes, I tried a reset and restore. With the advice and answers posted here, I will soon try to replace the hard drive and post an update after the repair. Thanks everyone for your help.
UPDATE: After the first teardown, the click wheel and the button stopped working properly. I replaced the hard drive, but still get a sad iPod logo. I can't navigate through the iPod to see if the first problem still exists. I will purchase a new click wheel and with the advice from an iFixit customer rep, a new hard drive cable. I'll replace the click wheel and click wheel button first. If the sad iPod still shows, I'll replace the hard drive cable. If it still exists, I'll have to purchase a logic board. More updates will follow as long as the repair endures.
Hey scott did you fix your ipod?
2 댓글 더보기
댓글 달기
답변 3개
선택된 답변
This usually means that your hard drive has gone bad. I had a classic that had similar symptoms that replacing the hard drive fixed.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
With your confirming advice, Nat (Thank you!), I will try to replace it very soon. I will post an update after the repair.
댓글 달기
ipod is dead, it does not turn on it does nothing, what could this be please.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Try a new battery?
댓글 달기
yae i had something like that and i fomat it from windows also you can use the disk utility in mac osx and rpair it if its not repair use earaze and then you must go to the itunes and restor it maby its work its sound the hard drive have problem or the data not readable
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
Scott 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 11
전체 시간: 6,661
