주요 콘텐츠로 건너뛰기
Before merging with HP, Compaq manufactured a full range of laptop computers. Now they are manufactured by HP mostly with basic features.
295 질문 전체 보기
Why won't my external mouse work
I am trying to use an external mouse on my Compaq laptop. It used to work fine but now doesn't even recognize when I plug it into the usb ports. I have tried all 3 usb ports and none of them recognize it, the mouse works fine on other computers. I have already tried updating the drivers and they are all up to date and have plugged other usb port device into all 3 usb ports (keyboard) and they work fine for that. I am tired of using the touchpad and want my mouse back....any suggestions?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Try using a different mouse and see if it works.
Try disabling the touch pad and plug mouse into USB port and see if get connected.
Try going to hardware manager , plug your mouse in USB, scan for hardware changes and see if it shows your mouse.
God Luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
i have tried using different mice and no look but I will try the other suggestions and let you know :) thanks
댓글 달기
I went into device manager and went down to Universal Serial Bus Controllers. A lot were errors. I went to {Update Software] { Browse computer} { hit the blue rectangle under browse and clicked the (Microsoft) one. Its probably different but look for usb hub connecters and follow that.
Just saying I'm not 100%
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Susan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 9,108
