주요 콘텐츠로 건너뛰기
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 질문 전체 보기
Do I need new adhesive for iPad mini logic board and battery?
A friend gave me his broken mini (shattered screen) and I have the replacement front panel w/digitizer, IC and and home button shipping. This part comes with new adhesive strips.
The corner of the unit was bent in, and the case has some scratches and marks so I figured while I've got it open, I might as well transplant the guts into a new rear housing as well. I found a rear housing for 30 bucks online. So, basically I got a nearly brand new 1 gen Ipad mini for $117 plus the fun of taking it apart.
My question is when I (carefully) heat and remove the logic board and battery, do I need to have some kind of adhesive strip ready to install into the new housing, or will the old adhesive on these two stick with a little heat and pressure applied? Also, think I'll be able to reuse most of the old tape if I'm careful?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
You can reuse the adhesive! Just make sure that the adhesive comes up with the battery and the logic board. If the adhesive sticks to the frame you can still transplant it to the new rear case, but it will be a little harder to keep the strips from bunching up in areas.
Good luck! Let us know how it goes. The iPad Mini can be a challenging repair!
I'm glad you got a part with the IC connector already soldered on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Are the adhesive under the logic board of ipad mini really necessary, because i destroy some of them(mix of metal and adhesive).
Thank you
댓글 달기
귀하의 답변을 추가하세요
wasloan21 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 268
