Great Jason, nice to see that the cleaning worked for you. I finally managed to fix my problem as well, however the cleaning didn't help. It took me almost 4 months to understand what was wrong. I'll explain the best i can.
This was my problem and solution:
The prongs underneath the actual earpiece is only supposed to touch the copper plates, not actually that much force, if they are pushed too hard, it will not work.
So i got an original screen and found that when i disassembled it there were two very very small plastic squares with hole in them(for the screws), and is working to keep a good distance for the screws(so they are not screwed all the way into the bottom).
As i ordered my new earpiece and flex cable these small plastic squares were not included. So without them the screws were reaching the bottom and pressing the earpiece too far down and the prongs were too hard against the copper plates. So it should be firm with a loose fit(that the plastic squares solves). I guess if you lost these plastic squares you could probably improvise, but there is no way to order these parts(as to what i have found yet).
A good tip is to take an old broken screen from someone and use the plastic parts from that earpiece to yours if you lost them.
This was one tricky thing to figure out, since none else have seemed to explain a good solution. I hope i made it clear with the explaining part, if not please respond and i will explain further.
To IFIXIT staff: This is a really important part to include to the guide, perhaps you can make some adjustments?
댓글 11개
I'm having the same issue, need an answer for this
George Pate 의
I'm having the same problem. Changed the front camera along with the cables as well as the earpiece, still not working. Checked and triple Checked all cables, still no sound from calls. Is it the actual new screen that is not right? Expensive though. Please help!
Andreas 의
I have this same problem. I slightly ripped my ear speaker flex cable when changing the screen. Just ordered a new flex cable and will be installing it this weekend and hoping it that it works.
Alex 의
Please Alex, could you confirm if the issue has been solved with the new piece?... I have the same issue, and i think my problem is that flex cable.
Thanks.
Frank 의
Going through same problem just that sometimes when i tap at back or front it use to start working. Need a solution tapping is not working anymore
Aniket ingle 의
댓글 6개 더보기
