주요 콘텐츠로 건너뛰기
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 질문 전체 보기
Battery Change Didn't Cure My Problem
1. I changed the battery and the Nano seemed to work fine for a day ot two. Now the same condition reappeared of no battery charge. It only plays when powered by external device like Docking Station or when plugged into the computer.
Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
sounds like the new battery is empty or there is something wrong with the power circuit - something drains the battery - was there a fluid damage or something like that ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hello,
Thank you for taking the time to respond. I was also thinking that maybe that something could be wrong with the power circuit resposnible for recharging. Ifixit is sending me a replacement battery. This one will tell the story but I dread reopening that Ippod. No no battery leakage.
opening the first gen. isn't that bad - newer ones are horrible ;-)
dorry - i didn't mean a battery leakage - i ment water or any other "non technical" fluid
sometimes the slightest fluid damages could make problems - check and maybe clean the dock connector with a paintbrush and rubbing alcohol.
i've seen this many times on cell phones - a little damage (or dirt) on a dock contact could be able to make charging problems
댓글 달기
귀하의 답변을 추가하세요
tomasnie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 639
