주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
질문 마감됨
MacBook 5 Beep Sound not booting up.
Hello
my macbook gives a 5 beep sound on booting time and not booting up after this.
its working before suddenly hangup i forcefully shutdown the mac as it is hangged after that this problem occurs please suggest what to do to fix this problem
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I checked again and found 3 beep sound is coming. according to mayer
3 beeps = no good banks So what is solution now
댓글 달기
답변 2개
선택된 답변
Sounds like you pooched your CPU. Need a new logic board. OR if you dropped this machine before this started you could have knocked the RAM loose if you're hearing a single beep every 5 seconds repeating.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Reseat the RAM, replace the RAM.
댓글 달기
가장 유용한 답변
The beeps are to tell you what's wrong, let us know what you're getting for a possible fix:
1 beep = no RAM installed
2 beeps = incompatible RAM types
4 beeps = no good boot images in the boot ROM (and/or bad sys config block)
5 beeps = processor is not usable
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
according to you 3 beeps = no good banks So what is solution now
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 3,669
