주요 콘텐츠로 건너뛰기
The RIDGID R84015 X2 is an 18v, 1/2 inch chuck, cordless drill.
6 질문 전체 보기
Battery no longer holds a charge
The 18v batteries for my RIGID tools (drill and reciprocating saw) no longer hold a charge.
The charger even signals that one (I have 2 packs) of the batteries is defective (blinking red & green lights).
Do I have to replace the packs (over $100 each) or can I possibly replace the cells inside the packs?
Thanks in advance,
Paul
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
paulk524, you can replace the cells. Take a look on here . Biggest issue will be to open the battery pack. Once you have it opened, the repair will be similar to this Repairing a Cordless Drill Battery or this one Repairing Black and Decker - TS221 Ranger CD2000 Battery Should cost you no more than around $40 to rebuild the battery. Hope this helps, good luck.
Power Drill 이미지
안내서
난이도:
운영
Black and Decker TS221 Ranger CD 2000 이미지
안내서
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
paulk524 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 35
전체 시간: 16,714
