Guide to replace Keyboard?
Need to replace keyboard on a Acer Laptop Aspire 7551G.
좋은 질문 입니까?
좋은 질문 입니까?
Curd, this should be it :"First, remove the battery.
Now, using a small screwdriver, push back the 6 sliding clips while lifting up on the keyboard. These clips are above the 'ESC', 'F4', 'F8', 'F12', 'Del' and 'End' keys.
Set the keyboard on its face to access the keyboard cable lockdown connector.
This final step is unlocking the keyboard cable from the motherboard. To do this, simply lift up on the black connector and you can slide out the keyboard cable.
Reverse procedure to install your new keyboard.
Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 161
