주요 콘텐츠로 건너뛰기
1.6, 1.8, 또는 2 GHz G5 프로세서
131 질문 전체 보기
Why does my computer freeze/shudown while watching youtube videos?
while watching youtube videos, the computer will shut down or a black screen will appear. If i press escape several times, it comes back up and returns to the video.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
How much ram are you running?
Could be an issue with the flash plugin. Which browser do you use and is the plugin up to date?
댓글 달기
답변 3개
선택된 답변
Go under the Apple in the upper left hand corner to "About this Mac". Please give us the operating system information and the amount of RAM. Then go to www.firefox.com and download their browser. Try using that and see if it still shuts down. If if does, then I need you to open it up via the three screws on the bottom of the frame and examine the capacitors (cans) for corrosion and/or bulging (a major issue with this model series). We'll go from there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
+ Ralph
댓글 달기
Nicole, you may wish to setup a Genius Bar appointment at an Apple Store to have them look at this for. The issue could be any number of things. If it is happening during YouTube play back and not while watching other videos it is likely software related. The issue may be fixed by running "Software Update" which is available from the Apple logo in the top left of your screen. You can try a different we browser. For example, if you are using Safari you may wish to download FireFox (as mayer recommended) and try watching the same video again to test if you experience the same symptoms. There could also be corruption in your operating system which may require restoration. Whatever the case may be, backup any documents, pictures, music or movies that are important to you before taking it somewhere for help.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I dont know much about computers, so where can I find the RAM info as well as the plug in info?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
nicole 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 5,314
