2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
678 질문 전체 보기
Backlight not working after LCD replacement
Hi.
I have a MacBook 6,1, serial MC207xx/A and the LCD start flickering, so I replaced it. I replaced it because with an external monitor it worked, and because I knew it was because of the junction of the board with the LCD itself that, for some reason, was not working in some positions. (The new monitor is this one).
After replacement, the backlight was not working (I could see things on the LCD, but very dim). Thus, I changed back to the old LCD to confirm that the backlight was also not working anymore.
I reset the PRAM (option+cmd+R+P) and it still doesn't work.
From the different posts in this website, I tend to think that I might have blown the fuse for the blacklight.
Can someone help me to fix it, or give me some advice on how to do it? I don't know how to solder, but I might have a friend that can do it.
Edit: I confirmed it is not the cable or the monitor: I substituted a full display from another working machine to this one and the blacklight is also not working.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Could have been the inverter board or cable all along. Cables on these get lots of abuse. Look over the cable for nicks, crimps loose connections.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thanks for the reply. The inverter board was not for sure since I was very careful with the new LCD (and the old one was fine). The cable is hard to tell. I had changed the original screen twice and had no problems with the cable. How can I test it?
의 답변
I have no suggestion other than continuity test (flex it a bit as it is in use).
의 답변
Since the MacBook A1342 uses a LED backlit LCD, there's no inverter cable. All data and power is transmitted through a single cable.
의 답변
Many times he said he had an LCD (but the link is to an LED). He also claims he checked an inverter board. The identifier (6,1) is for a MBA. We're really getting conflicting information here.
의 답변
It is an LCD with an LED (instead of CCFL) backlight
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
jorgecarleitao 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 811
