주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
원래 PowerMac G3의 뒤를 이어 1999년에 출시되었습니다, 300-450 MHz, 64 또는 128 MB RAM, 6 또는 12 GB HDD
18 질문 전체 보기
Can my B&W-gone-Debian take a harddrive larger than 128GB?
So, as Google will reveal, the PowerMac G3 B&W does not support harddrives larger than 128GB. However, with the help of a friend, I recently turned an old B&W of mine into a server running Debian. I popped a 250GB drive in, and after a couple of formatting procedures, Debian recognizes that I've got a 250GB installed. So my question is, is it safe to use, or will it be that once I get past 128GB that my data will all corrupt?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
Nintendo Switch 키트 쇼핑하기
Nintendo Switch 키트
게임으로 돌아가기 위한 빠른 해결책
답변 2개
선택된 해법
It may work, but there's a good chance that if put more then 128GB of files on the drive, it may begin to act up. I have one of these, and it's given me a heck of a lot of trouble with hard drives. From what I've read, the IDE controller (REV. A) can be incredibly unreliable. On the other side, theres a chance that the limit is bypassed by the linux bootloader and may mask the full capacity of the drive until the operating system has begun to load, since when you install linux on a mac, it installs a GRUB-Like boot manager (Or at least it did on my mac). This may bypass the limit through the that.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
I'll try duplicating my iTunes library a couple times on it first then. Hopefully, that will let me know if it's running into problems or not.
What's the easiest way to find out if I have a rev. a or a rev. b?
I'm not sure, i've been told to check on top of the chips, but i can't tell with mine, The Rev. A is very unstable and unreliable compared to the REV. B. I'llread up on it, and see if theres a way to physically tell.
I found a way to differentiate between the two of them (thankfully I have rev. B).
Here's a link to the site I found the information on: http://www.xlr8yourmac.com/G3-Zone/yosem...
의견 추가하세요
Unfortunately it won't see a drive larger than 128 gigs. The hardware is 28 bit and not 48 bit so can't address drives that large. However, according to this page: http://www.forevermac.com/1999/08/g3-blu..., a patch can be applied to circumvent the limitations. Not sure if Debian has the patch for 28 bit Chipsets.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Josh Calvetti 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,145
