2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
338 질문 전체 보기
Formating Error on Second harddrive
I just installed my upgrade kit (this) and a second harddrive instead of the dvd-drive. The Drive appears in the settings, but when i try to format or erase it i get the following error:
"wiping volume data to prevent future accidental probing failed "
i also tried to boot with the tools, but the same error occured
Unibody Laptop Dual Drive 이미지
상품
$24.99
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
originally there was a 256GB Cruicial M4, now i added a 1 TB WD Red in exchange for the dvd-drive.
의 답변
That drive was not on the list of possible suspects. Now you know why.
의 답변
so would it work if i switch the postions?
의 답변
Are they not the same size? I will test tomorrow
의 답변
The one I looked at spec'd a 3.5 in drive,,, your OEM is a 2.5 inch… I think you'll also get overheating/battery life issues with that large of a drive.
의 답변
2에 댓글 더 나타내기
의견 추가하세요
1개의 답변
선택된 해법
Kit says: Does not include hard drive. We recommend a 240 GB SSD, 500 GB 7200 rpm drive, or 750 GB hybrid drive. What drive did you choose? The problem could be the drive. Or the cable.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
KlawWarYoshi 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 274
