주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3918 질문 전체 보기
Can I put a iPhone 5 screen on a iPhone 5s?
Can i put a iphone 5 screen on a iphone 5s?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
PC 노트북 배터리
큰 전력 향상을 위한 손쉬운 수리.
지금 장보기
4개의 답변
가장 유용한 답변
no
so are the iPhone 5 and iPhone 5s screens interchangeable
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
You answered "no" as if the link you referred to answered the question. I'm not sure if it is possible, I am not saying that. However if you had an iPhone 5s LCD assembly you wouldn't need the home button it would be attached to the LCD screen you would be replacing. Before everyone just takes everyone else's word for it, because The question actually has not been answered, maybe there should be more discussion before this subject is closed. There are many reasons for wanting to do this, for one I don't use my fingerprint scanner and could care less about it. I have about five iPhone five screens and they would come in handy because like everyone else I've broken my share of screens. I understand the parts from an iPhone 5s screen will not fit with an LCD from an iPhcone 5. But can anyone say for sure that the ribbon is not the same, if I recall the iPhone 5s just has an extra ribbon for the home button for the fingerprint sensor. The iPhone 5 LCD only has the home button attached to the entire assembly. The real question would probably be, does the LCD ribbon and digitizer ribbon fit the motherboard and also will the missing fingerprint sensor cause errors with iOS.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Bobby, the answer is no. The Ribbon cables and connectors are all different. The image should help you to see the difference.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
no you can't because the new home button they are different and some more part
but you always can order one good quality in the online store or ebay
I find you here one for example :
http://www.ebay.com/itm/151269627651?ssP...
I hope that its help you :)
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
gaga323 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 22,461
