주요 콘텐츠로 건너뛰기
Repair guides and support for water softening systems.
How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개:
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
Water pressure drops from time to time in the kitchen faucet or bathroom shower
댓글 달기
답변 2개
this might help
http://docshare01.docshare.tips/files/12...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Crystal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 1,244
