주요 콘텐츠로 건너뛰기
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 질문 전체 보기
질문 마감됨
After YLOD repair, controller won't connect
Hi,
I successfully used the YLOD repair kit from ifixit to repair my overheated PS3. Everything seems to work great, except the PS3 controllers will not wirelessly connect to the system. I tried resetting the controllers and also tried pressing the PS3 button down for awhile after connecting with a USB cable with no luck. Any other advice?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Can your PS3 connect to WiFi?
It sounds like you forgot to hook up the bluetooth/ wifi cable
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I took it apart last weekend to check it out and the ribbon that connects the bluetooth/wifi cable popped right out...so you're right jzpittm. At least it was an easy fix. Thanks!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi,
I ve got the same problem : try to reset the controller (Button at the rear)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 637
