1.83 GHz Core Duo 또는 1.83, 2, 또는 2.16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
260 질문 전체 보기
CD Stuck iMac Dead Kind of piece blocking to try "manual"
Hi,
We have a iMac Intel 17" with no keyboard or mouse, well, we have general pc keyboard and mouse.
The Mac starts up, it seems to load but then nothing happens and a white screen stays forever.
We've tried to pull it out with tweezers but there is a kind of metal piece, like a small coin, in the middle of the entrance of the drive, so we cannot pull out anything.
We are trying to remove it to be able to start up the computer with a firmware recovery.. It is an old model and we are just curious about it, if not, we will just tear it apart to experiment :)
Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Sounds like you'll need to pull off the display assembly and then carefully remove the optical drive to get the object removed.
Have you reviewed the IFIXIT guides Yet? Heres the one on how to remove the optical drive iMac 17" Optical Drive Replacement. In this case you may not need to replace the drive just repair it.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Ivan 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 96
