Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
170 질문 전체 보기
Can I swap original HD for a SSD Hybrid 3.5"?
I would like to know if its possible to just do a simple swap of the original hard drive in the iMac, with a SSD instead.
I understand I can add an additional drive by taking out the optical drive, but I simply want to take out the original HD and replace it with a SSD.
Is this possible and how ?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Jose -
Just to be clear here you want a hybrid HD (HD with SSD caching as one device) Vs replacing the HD for a straight SSD correct?
I would strongly recommend the hybrid HD direction first. Follow this IFIXIT guide iMac Intel 24" EMC 2267 Hard Drive Replacement. You do need to make sure you get the correct SATA I/O speed drive. Your system can support a SATA II (3 Gb/s) HD or hybrid drive.
Seagate makes a good unit, review your options and lets us know which one you are thinking of.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I was thinking to replace my original 640 Gb HD with a straight SSD drive.
Would the above be faster than replacing it with a HD Hybrid ?
의 답변
Yes a SSD is faster but at what cost and is the system you are using it in going to benefit from the added speed. Frankly, Your system is not going to get much improvement from a straight SSD solution over a hybrid drive. With a hybrid you gain the speed of the SSD but you still hang onto the storage space a HD offers and the price per MB is a lot lower. Bottom line here I would go with the hybrid drive.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Jose 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 350
