주요 콘텐츠로 건너뛰기
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
156 질문 전체 보기
Why will my Gameboy Advanced SP will not charge or turn on?
I got a GBA SP from my friends and I tried turning it on but it would not turn on. I then plugged it in to the charger. It flashed orange really quickly and then would stop charging. (Note: My OTHER friend said that the battery swells up on those things and it looks like that might be the case but I don't know how to fix that either.) If someone could help me figure that out I would be pretty happy!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 7
댓글 5개:
Same thing for me, but the battery replacement didn't work
I've diagnosed the problem with mine, the wiring between the charging port and the battery is somehow broken.
Do a bridge on the F2 fuse.
i have that same problem
댓글 달기
답변 4개
Tommy the very first thing you want to do is to change your battery. Here is the guide for it. The battery is available at places like this. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Already did. No help
댓글 달기
I think you should bye a new gameBoy Advanced SP
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
All you need is a new battery :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tommy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 12,431
