주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
297 질문 전체 보기
disassembly guide for iMac Intel 21.5"
Have you produced a guide for the disassembly for this model or, if not, which guide would be most similar?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Thank you for your interest! We do not have a guide yet for this machine.
We have a teardown for the 27" iMac, which is relatively similar, but no repair guide for either yet (as it is a very new machine). Check back often, as we are constantly adding new content!
In terms of similarity, the new iMacs are fairly unique inside, so nothing directly compares yet.
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks, that is an excellent teardown article. Just one part that still puzzles me. Where should the two suction cups be placed to 'safely' remove the front panel? There is a note that says that the panel rotates up from the bottom side and yet the photos show them placed at diagonal corners. If it rotates from the bottom, shouldn't the suction be placed at the top corners? Thanks.
This may be the note you are already referring to, but this describes with more detail how to safely remove the glass (it says to put the suction cups near the top edge).
댓글 달기
I couldn't find one on 21.5 but here is the teardown for 20". You can view it and compare to your unit and see if it compares. Ralph
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I found a nice one here iMac Intel 21.5" EMC 2308 Logic Board Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
@Jeff Smith, hopefully the OP got it fixed within the last 4 years ;-)
댓글 달기
귀하의 답변을 추가하세요
dave 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 42,284
