주요 콘텐츠로 건너뛰기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 질문 전체 보기
Why Ipad 2 doesn't charge battery more than 7%?
So I have this Ipad,and it's not even 2 years yet and it barely was used, and suddenly one day when I tried to charge it, I left it charging for several hours but the battery didn't pass 7%...switched cables,none of them were bad,neither the ipad charger,and I also conected to my sony dock to charge it and it was still stuck...And on the same day the battery kept dropping to 5, and now 2 % and it doesn't pass that,tried factory resetting but nothing worked,what should I do ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Hi Lucas,
Could it be a defective connector? does the IPAD indicate that it is getting power?
If it does not indicate getting power and just drops %chage, then if no warrenty left open the device and measure charge voltage on the battery and the charge connector pin in the device.
If connector issue, try with charger insertes to press in different directions to determine if connector is broken. Also inspect inside connector cavity - someting stuck or disconnecting? use magnifier or better.
Best of luck. /Carsten
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Lucs,
Is it possible then to turn it on when power adapter is inserted? (even if it is discharged?)
Br Carsten
댓글 달기
Hi Carsten,
The Ipad does indicate it's getting power,unfortunately I let it run out of battery and now it doesn't turn on anymore,but when you put it to charge it says it's getting energy to charge but doesn't...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi Lucas,
I suspect the charge controller IC (chip) is refusing to charge the battery or that the battery protection circuit is faulty.
The only advice i can give then is to replace the battery pack (or via repair shop).
And just to be sure, you did the Reset procedure? if not try it with the charger inserted.
Reset:
• Press and hold the Sleep/Wake button and the
Home button at the same time for at least 10
seconds, until the Apple logo appears
Q: does it respond if connected to PC/Macbook via Itunes?
Br Carsten
댓글 달기
귀하의 답변을 추가하세요
Lucas Vasques 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 1,103
