메인 콘텐츠로 스킵하기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
371 질문 전체 보기
Faulty LED replacement instruction
Hi All,
After getting flickering screen which then got worst and then all am getting is blank screen I took my MacBook Air to Apple store and genius there confirmed to me the fault is with the LED and not the screen itself.
What he did he flashed a light to the back of the screen were the apple logo is and en you can actually what is on the screen.
Apple advice was to replace the whole display assembly which cost almost the same as much as I paid for the MacBook Air itself..
Is it possible to replace only the LED ?
Thanks in advanced
Ahmed
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
Yes it can be done. It is a very '''advanced DIY project'entailing dismantling and reassembling much of the laptop.'' I would not start this as a first DIY laptop repair.
Almost as difficult is just replacing the display with the top cover already included.
For either you need the proper tools (every job is easier with the correct tools.)
You need to study (not just read) the guide - many DIYers do more damage when they tear components off the logic board by not unlocking cams, or pulling the wrong direction.
Once you get your old display out on the back you will find the manufacturer's part number which will allow you to find replacement screens. The display alone would not cost as much as the preassembled display & cover - (but time is also costly) .
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank machead3 for your answer but am interested if I can do any troubleshooting steps to repair the LED without replacing the whole screen ?
I had a look on eBay and the screen itself is not expensive however many posts on this website describe how replacing the LCD didn't fix the LED backlight issue..
So do I need to change the LCD cable, fuse or the whole screen ?
Thanks again and Merry Christmas :)
의 답변
Doing a "shade tree mechanics" version the cable is cheapest and easiest, then the display, lastly the controller/fuse (that really is not a job for an amateur- soldering logic board components requires special tools, solder and lots and lots of experience as it's easy to burn through a multilayer board). Not to mention obtaining the part… generally a DIY "fix" is an entire logic board replacement.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
ahammadi 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 847
