주요 콘텐츠로 건너뛰기
모든 연령의 아이들 장난감에 대한 포괄적인 수리 안내서 세트입니다.
950 질문 전체 보기
Where can I find a voice box for this toy?
I have a 1995 Woody the Cowboy Doll. This is the original Woody doll that came out in 1995 after the movie premiere. It has (mine had) a pull-string on the back that made him talk. Mine has no voice box or the string.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 3개
I would just like to buy a new voice box for the woody doll take the old one out and put the new one in or send the doll to someone to fix it has it is the original one and my son is now 22 please
How about an offer from the online store https://babyuniquecorn.com/collections/s.... This is a children's toy store where I shop regularly.
ok get a woody doll and do this in order or it will now work ok ok get the woody doll get a new woody doll then get the new woody doll´s string and un tie it hold the string and keep it in your hands or it will go in the box and you cant get it out take out the old voice box in the old woody doll put it in ther still hold the string and pull the string up the hole the you pull the string at ok if you did that the plastic that you untied tie it back on hot glue it anwere and boom it shold work hope this is help full
댓글 달기
답변 2개
선택된 답변
Julio,
Here you go: check this out on ebay. You can use this one or just cut the voice box outa of it and install it in yours.
I hope it works!
Frank
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
You could always make a voice box, like this guy did in one of his youtube tutorials: https://youtu.be/lszRgWZN_B0
If you can't manage to fix the pullstring mechanism, here's something else you can do.
1.) Open up the voicebox and remove the mechanism itself. Figure out which wires need touched together to make him talk. You may or may not want to lengthen the wires depending on where you want the button to go. Get a pushbutton mechanism. You can either buy these brand new, or snatch them from another broken toy (I used a pushbutton mechanism from the laser off a Buzz figure and managed to barely fit it inside Woody's voicebox. Solder together the button and the wires. Before you put the voicebox back inside the toy, Test the heck out of it to make sure everything is connected properly. Those old wires disconnected on me a couple times when I was putting it together. Put the voicebox back inside, and close up Woody. Remember where that button is so you know where to press to make Woody talk.
If you happen to find a Gabby Gabby doll anywhere, they have the same voicebox. Maybe you could swap ‘em out.
You can always go on Etsy and buy a replacement: https://www.etsy.com/market/toystory_woo...
You can also try ebay: https://www.ebay.com/itm/394788950509?ha...
You can also watch some repairs: https://youtu.be/CBcID8AyuXQ or https://youtu.be/8EKBZQ12Npg
I hope this helps, Thanks!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Julio Salazar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 10
30일 전: 50
전체 시간: 12,985
